OBD2 EMULATOR
CCKATANA
OBD2 EMULATOR
Post by CCKATANA »
HELLO I WANT TO ORDER YOUR PRODUCT JUST HAD A FEW QUESTIONS DOES UNIT HAVE TO BE PLUGGED IN TO COMPUTER TO RUN TEST OR CAN I LOAD DATA IN UNIT THEN UNPLUG FROM COMPUTER AND THE DATA STAY STORED IN UNIT. ALSO CAN DTC CODES BE SET TO ON AND OTHERS SET TO OFF
Re: OBD2 EMULATOR
The emulator does not require computer to work. However, to change the emulation data, you need a control interface and that's either a computer or an iPhone/iPad. The emulator has serial UART connector and that's for programmatically controlling with an external device (e.g. an Arduino).
