Not working with ECUFlash
alex35
Post by alex35 »
I bought your emulator specifically for using with ECUflash software/hardware.
It is not working. ECUflash does not recognize the commands (or responses) from your emulator.
It times out on each command. Do you have the solution for the problem?
I believe that ECUflash is the most popular software for ECU programming.
