I've purchased two One+ Model H for our cars and connected them to Traccar which works fine. However, I'm getting somewhat annoyed by the permanent flashing LED and the beep tone while driving. I quickly went through the configurable parameters on the telelogger source, however I can't find anything that relates to this. Could you please lead me into the right direction?
One+ Model H, disable LED and Beep
Re: One+ Model H, disable LED and Beep
Both the LED and beeper can be turned off in you look at the code. Search for "PIN_LED" and "beep" in telelogger.ino.
