error: 'class HTTPClientSIM7600' has no member named 'getSignal'
#include <FreematicsPlus.h>
//#include <lib/FreematicsPlus.h>
// testing URL: https://hub.freematics.com/test
#define SERVER_HOST "hub.freematics.com"
#define SERVER_PORT 443
#define SERVER_PATH "/test"
#define CELL_APN "Hologram"
#define CONN_TIMEOUT 5000
FreematicsESP32 sys;
HTTPClientSIM7600 net;
int errors = 0;
bool init_net()
Serial.print("Init cellular module...");
if (net.begin(&sys)) {
Serial.print(net.deviceName());
Serial.println(" OK");
} else {
Serial.println("NO");
return false;
Serial.print("IMEI:");
Serial.println(net.IMEI);
if (net.checkSIM()) {
Serial.println("SIM Card OK");
} else {
Serial.println("No SIM Card");
Serial.print("Registering on network...");
if (net.setup(CELL_APN)) {
Serial.println("OK");
} else {
return false;
String op = net.getOperatorName();
if (op.length()) {
Serial.print("Operator:");
Serial.println(op);
Serial.print("Obtaining IP address...");
String ip = net.getIP();
if (ip) {
Serial.println(ip);
} else {
Serial.println("N/A");
int signal = net.getSignal();
if (signal) {
Serial.print("RSSI:");
Serial.print(signal);
Serial.println("dBm");
Serial.print("Init HTTPS stack...");
if (net.open()) {
} else {
return true;
void setup()
Serial.begin(115200);
// use following for Freematics ONE+
sys.begin();
// use following for Freematics Esprit or other ESP32 dev board
//sys.xbBegin(115200, 16, 17);
// initialize cellular module
while (!init_net());
void loop()
if (errors > 10) {
// re-initialize cellular module
net.end();
if (init_net()) {
errors = 0;
} else {
delay(3000);
return;
//Lets test SMS (my added code)
if (net.state() != HTTP_CONNECTED) {
Serial.print("Connecting...");
if (net.open(SERVER_HOST, SERVER_PORT)) {
} else {
Serial.println(net.open(SERVER_HOST));
net.close();
errors++;
return;
// send HTTP request
Serial.print("Sending request...");
if (!net.send(METHOD_GET, SERVER_PATH, true)) {
Serial.println("failed");
net.close();
errors++;
return;
} else {
// receive HTTP response
Serial.print("Receiving...");
char *response;
int bytes;
response = net.receive(&bytes);
if (response) {
Serial.println("-----HTTP RESPONSE-----");
Serial.println(response);
Serial.println("-----------------------");
errors = 0;
} else {
net.close();
errors++;
Serial.println("Waiting 5 seconds...");
delay(5000);
