SIM connection problem +CGREG: 0,2
Posted: Mon Aug 07, 2023 11:35 pm
I have a One+ Traccar Edition and using it with the supplied hologram SIM. In the config.h file, I set the APN to hologram:
But the device keeps searching for a sim connection:
Hologram support said:
// cellular network settings
#define CELL_APN "hologram"Code: Select all
CPU:160MHz FLASH:4MB
IRAM:342KB
DEVICE ID:A0HN863A
TYPE:16
MEMS:ICM-20948
ACC BIAS:-0.03/-0.01/1.00
GNSS:NO
OBD:NO
[ 11819][E][sd_diskio.cpp:802] sdcard_mount(): f_mount failed: (3) The physical drive cannot work
[ 12319][E][sd_diskio.cpp:126] sdSelectCard(): Select Failed
NO SD CARD
[CELL] Activating...
CELL:SIM7070G
IMEI:X
[CELL] Searching...
[BUF] 15 samples | 150 bytes | 5/32
[BUF] 21 samples | 210 bytes | 7/32
[BUF] 27 samples | 270 bytes | 9/32
+CGREG: 0,2
+CGREG: 0,2
[BUF] 33 samples | 330 bytes | 11/32
[BUF] 39 samples | 390 bytes | 13/32
[BUF] 45 samples | 450 bytes | 15/32
[BUF] 51 samples | 510 bytes | 17/32
CELL:SIM7070G
IMEI:X
[CELL] Searching...What can I do to make it work?We dug into the SIM and it appears that it is connected to the Network and opening sessions. The Hologram SIM is working as expected on the Network, allowing the device to open sessions. However, the device is not sending any data through that open session.
