Freematics Builder no Serial Port Option (Freematics ONE)
nunosan999
Post by nunosan999 »
I am attempting to configure the APN configurations on a Freematics ONE device, via the Freematics Builder, version 1.2.3. I am able to load and build the telelogger.ino file.
But I see no option to upload the configurations, ie, no serial port options, as per attached screenshot.
I have the device connected to the PC via USB and it lights up red and beeps when I connect.
How can I troubleshoot this connection in order to upload the configs on my device?
Thanks in advance
nunosan999
Re: Freematics Builder no Serial Port Option (Freematics ONE)
Issue sorted. USB COM serial port driver was not installed. Used Windows device manager to update the driver and everything now working as expected.
villagetunic
Post by villagetunic »
You are correct; the screenshot you may have seen for previous versions of Freematics Builder appears to be out of current. Here's how to troubleshoot the connection and upload setups for your Freematics ONE device with Freematics Builder version 1.2.3.
nodeshand
Post by nodeshand »
This is exactly the information I was looking for. Thanks for the answer. :)
demurejunkie
Post by demurejunkie »
Nobody put in the driver for the USB COM serial port. After updatingbasketball stars the driver through Windows' device manager, all functionality returned to normal.
celemtine
Contact:
Post by celemtine »
nunosan999 wrote: Thu Apr 13, 2023 10:57 pm Issue sorted. USB COM serial port driver was not installed. Used Windows device manager to update the driver and everything now working as expected.
Thanks for the info, I had this problem with my device yesterday so I came looking for an answer and this one helped. Thanks for your contribution.
storagenestle
Post by storagenestle »
Ensure that the necessary USB drivers for your Freematics ONE device are installed on your computer.geometry dash Without the correct drivers, the device might not be recognized correctly.
