SD card mounting issue with latest ESP32 Arduino package
If you encounter SD card mounting issue, change following line in platformio.ini
platform = https://github.com/platformio/platform-espressif32.git#feature/arduino-upstream
to
steff999
Re: SD card mounting issue with latest ESP32 Arduino package
Post by steff999 »
I still have this problem when building with platform.io
[ 13178][E][sd_diskio.cpp:126] sdSelectCard(): Select Failed
[ 13178][E][sd_diskio.cpp:795] sdcard_mount(): f_mount failed: (3) The physical drive cannot work
[ 13481][E][sd_diskio.cpp:126] sdSelectCard(): Select Failed
I already changed the mentioned line in platformio.ini, but this sadly doesn't help.
Use the latest ESP32 Arduino package in PlatformIO now like following
[env:esp32dev]
platform_packages = platformio/framework-arduinoespressif32 @ https://github.com/espressif/arduino-esp32.git#2.0.4
board=esp32dev
board_build.f_cpu = 160000000L
framework = arduino
monitor_speed = 115200
