Freematics One + Model B shows Memory dump at 0x400ed8b4: ffffffff ffffffff ffffffff
Posted: Thu Apr 08, 2021 4:02 pm
I tested FreeMatics One + Model B last year and everything worked great - information could upload to Mini server in cloud.
The device was offline and kept in a dry place last year. These few days, I need to re-visit this project, however, when running the telelogger,
,but FreeMatics One + Model B can not connect to any WIFI(tried different routers/APs Netgear, 2 models of TP link, Synology, Dlink, etc) and
doubt if the wifi model inside FreeMatics One + Model B died. In order to further test it, loads different codes
under firmware_v5 and firmware_v4(with a mistake) and finally screw up the pre-build binary in FreeMatics One + Model B .
It shows below error every time when boots up :
Guru Meditation ErrGuru Meditation Error: Core 1 panic'ed (Unhandled debug exception)
Debug exception reason: Stack canary watchpoint triggered (loopTask)
Guru Meditation Error: Core 1 panic'ed (Interrupt wdt timeout on CPU1)
I need your help to see :
a. if can give me instruction to restore the factory setting / pre-binary of FreeMatics One + Model B.
b. how to check if WIFI module inside FreeMatics One + Model B is damaged or I need to order another new one.
Thank you for your help.
Best regards,
Victor
Best regards,
Victor
