Logger: Datarate
Gauner
Logger: Datarate
Post by Gauner »
Hey,
can somebody tell me the approximate data rate that the OBD-II/MEMS/GPS Data Logging Sketch for Freematics ONE produces on the SD card?
I cannot find a configuration for the PIDs to log and the time rate in which it takes a log point.
If I had that, I'd only needed the size of a data point. :-)
I want to estimate the needed size of the sd card and the data volume per month i need for the cellular connection.
Thank You very much.
Gauner
Re: Logger: Datarate
Post by Gauner »
Ok, I found the setting for the time rate in datalogger/config.h,
#define MIN_LOOP_TIME 100 /* ms */
and inside datalogger/datalogger.ino I found the PIDs to log:
PID_POLLING_INFO obdData[]= {
  {PID_SPEED, 1},
  {PID_RPM, 1},
  {PID_THROTTLE, 1},
  {PID_ENGINE_LOAD, 1},
  {PID_FUEL_PRESSURE, 2},
  {PID_TIMING_ADVANCE, 2},
  {PID_COOLANT_TEMP, 3},
  {PID_INTAKE_TEMP, 3},
Is that correct?
Still I have no clue, how much data accrues in every loop.
Anybody a hint how to calculate this?
