Program the FreematicsONE+ correctly
Posted: Tue Mar 24, 2020 9:15 pm
I want to program the FreematicsONE+ correctly.
I found out, that the SIM 5360 doesnt run / start if I only put in 5 V to the USB- after the programming.
While with the FreematicsONE ( trackie) it worked like that -- only 5 V to the USB were necessairy...
So : I put 12 V directly to the OBD .... the SIM5360 worked !
It worked like 50 times.
No the USB to UART "FTDI " chip is broken. I replaced it (not that easy xD !). And it worked again !
Maybe you have an idea how to run the ONE+ correctly and if the 12 V were the reason for killing the USB to UART
Thank you
Thank you
