What's the 4G antenna setup for the SIM7600 on the ONE+ Model B?
It is one antenna onboard the PCB, and the U.FL connector for a second (mimo) antenna?
Is it required to put a second antenna on the U.FL connector - or does it help a lot? Do you have one you recommend?
Thanks!
what's the 4G antenna setup for the ONE+ Model B?
Re: what's the 4G antenna setup for the ONE+ Model B?
Built-in antenna or external antenna via SMA connector.
