Kia Picanto Issue
Posted: Sun Jun 02, 2019 7:09 am
Hi Team,
Have searched the forum to no avail - hopefully someone has encountered and solved this.
When connecting a MEGALOGGER HD to a 2018 KIA PICANTO the unit works as described but the vehicle goes into melt down displaying a fault with the Traction Control and the EAB (Braking) System.
Have tried the unit in two other vehicles including a 2015 KIA RIO and everything works as it should
I have uploaded the latest SKETCH - No change
Changed the OBD Baud Rate (Serial 1) to 9600 - No Change
Turned off GPS - No Change (other than no Red Cross next to GPS)
Changed OBD PROTOCOL from AUTO to PROTO_TSO_9141_2 - Both Errors disappeared from the vehicle and some tables of hex code appeared on the Arduino screen but it failed to move to display mode.
MEMS also has a Red Cross against it
Any thoughts ?
Any thoughts ?
