Will Freematics ONE be able to speak Subaru SSM protocol?
gfxguy
Post by gfxguy »
I'm looking at purchasing a Freematics ONE for logging and displaying data from my Subaru. I want to be able to access extended parameters that are only available via the Subaru Select Monitor (SSM) protocol, documented here: http://www.romraider.com/RomRaider/SsmProtocol
SSM over K-line uses UART settings: 4800 bps n, 8, 1. SSM can also work over CAN, described here: https://subdiesel.wordpress.com/generic ... 2-via-can/ . The open-source software RomRaider (https://github.com/RomRaider/RomRaider) implements both of these.
I'm hoping to be able to use SSM over CAN with the Freematics ONE. It seems like it *should* work, but if anybody knows any reason why it wouldn't, please let me know! Thanks!
Re: Will Freematics ONE be able to speak Subaru SSM protocol?
Extended protocols are not implemented.
gfxguy
Post by gfxguy »
Thanks for the reply. Are you aware of anything in the hardware that would prevent me from implementing this extended protocol myself using the Arduino? AFAICT it's just a layer on top of the existing protocols, and doesn't seem that complicated. Thanks!
