Freematics Hub & One+ gives Unauthorized Peer msg
Posted: Thu Jan 18, 2018 2:05 pm
Installed the telelogger sketch on my new One+ using the latest code from github.
Using WIFI as network thru hotspot on iPhone.
Setup the Freematics hub, opened firewall and TCP/UDP ports on the network.
The hub reports the client IP connection, VIN gets sent and client logs in. But when data is sent I get an "Unauthorized Peer" error from the hub.
Also turned on SD card but no data is being written there either??
