Access to additional I/O
mj43
Post by mj43 »
Is it possible to 'easily' access any of the I/O pins? For my project I need access to I2C and analogue pins to add some additional sensors. Are any of these available on the ten pads on the edge of the board?
Re: Access to additional I/O
Two GPIO pins (GPIO32/33) which can be used for analog input are led out to the 4-pin connector on the enclosure.
mj43
Post by mj43 »
Hi thanks, but aren't used by the GPS? Is there any I/O available on the 10 pins circled in the attached file?
fdsh
Post by fdsh »
I know it's an old thread. Did you find out how to use additional GPIOs?
Only two exposed GPIO can be used.
fdsh
Post by fdsh »
Can the external GPIOs be used to connect an I2C device? This would be an easy way to expand GPIOs, e.g. using a chip like this: https://www.instructables.com/id/IO-Exp ... d-Arduino/
