				Ignition on/OFF is not recognized on OBDII  Emulator
				Posted: Wed Nov 15, 2017 9:57 pm
				by shubham
				Hello Team,
I am trying to Ignition On/Off on GUi but it is nor recognized with my device.
Anybody can help me to resolve this issue.
				Re: Ignition on/OFF is not recognized on OBDII  Emulator
				Posted: Wed Nov 15, 2017 10:01 pm
				What OBD device are you using? The emulator does not simulate the voltage change between ignition on and off. If your device uses that as a reference for ignition, you will need to manually adjust the input DC voltage to reflect the change.
				Posted: Thu Nov 16, 2017 4:28 pm
				by shubham
				Thank you, I am using this on with my PC. My OBD II Device got powered on and working.
Here i want to change the  OBD parameters but none of the parameters are being reflected on OBD II devcie when i change it from freematics obd II software.
Can i get some support here ?
Steps:
1. OBD II software installed with software and my OBD II connnected.
2. Able to connect from software and seeing changes whenever i change protocol from CAN 250k 11 etc.
3. I connected my OBD II Device and trying to change parameters in the software.
   None of the parameters are being reflected.
Here i am looking fwd for your support.
your inputs are verymuch imp for me to bringup the emulator further.
> reflect the change.
				Posted: Thu Nov 16, 2017 4:48 pm
				by rjilvit
				FreeMatics OBD II emulator i am using.
Here Please let me know where is this option to manually adjust the input voltage.
Apart from this after the device is powered on I am unable to get OBD protocols changed.
Here I changed the Protocol type : This is not reflected.
In the protocol that is set i am able to see the currently set protocol but none of the PID gets reflected.
What is the use of GUI provided  by Freematics OBD II Emulator.  In the GUI if i change any of the PID it needs to be reflected on my OBD.
Please do let me know the OBD u shipped is damaged or what is the problem with this.
				Posted: Sun Dec 17, 2017 9:38 pm
				There is no way to change voltage on OBD pins. You need to adjust the input voltage of the emulator to archive this. Some OBD device might require a voltage change to start working.
The GUI is used to adjust the OBD PIDs and something else.
				Posted: Fri Feb 09, 2018 5:11 pm
				by alecg
				You cant change voltage on OBD pins. adjust the input voltage of the emulator to archive this instead
