Page 1 of 2
Library updates - Frematics One
Posted: Tue Jul 11, 2017 4:32 am
by Polkpolk
Hi Stanley
Just so you know.
The last 6-8 updates of the library have meant that the KWP ISO 14230-4 KWP 5 baud has not worked with Freematics One
Re: Library updates - Frematics One
Posted: Tue Jul 11, 2017 7:45 pm
by pingu_98
Yeah, I was trying my Freematics One out with the new libraries last Wednesday and couldn't get anything beyond the accelerometer working.
No ODBII (tried on 2 cars with compatible protocols) due to timeouts, no communication with the GPS (NO DATA NO DATA etc.) and a blank log file on the SD card (0 bytes).
Does anyone have any tips? I put the libraries into the latest Arduino IDE, compiled and uploaded etc. and connected from my laptop via serial.
Also, no success connecting to the BLE, via android (BT terminal app) or via my linux laptop, connections refused in both cases. I know that the app is for iOS, but surely there's another way to connect?
I see that there's a new update from 19 hour ago, I'll be trying again with this tomorrow!
James
Posted: Tue Jul 11, 2017 8:27 pm
Could you let me know which revision of code is working?
Polkpolk wrote:
> Hi Stanley
> Just so you know.
Posted: Thu Jul 13, 2017 2:20 am
by Polkpolk
> Polkpolk wrote:
> > Hi Stanley
> > Just so you know.
The attached zip is the version I managed to get some data from with Freematics One. If MEMS, OBD and GPS are enabled then no data will be written to SD. If GPS is disabled then data is written to SD. If SD is disabled, data shows in BLE monitor
I have to admit that I have never had Freematics ONE to work ok with KWP2000 5Kbps
Posted: Thu Jul 13, 2017 2:34 am
by Polkpolk
Cann´t upload the zip.
It´s from the 22062017 on GITHUB.
Posted: Fri Jul 14, 2017 3:32 am
by pingu_98
So I tried again yesterday with the Freematics One latest code on github. Here's the status:
Works:
SD card logging (MEMS data only)
MEMS accelerometer
Doesn't work:
OBDII functionality
GPS (no communications)
Not tested:
SIM800L SMS/GPRS functionality
I was suspicious about the GPS. I hooked it up to another Arduino directly, indeed it works fine at 38400 bps, in isolation. I tried changing the GPS baud rate in the datalogging sketch and the GPS test, but didn't change anything. I'm not sure what's going on, but it seems like anything running through the STM32 isn't communicating on my board. Anyone else having issues getting their GPS to work with the latest freematics one (V4) libraries?
Posted: Mon Jul 17, 2017 2:38 am
by Polkpolk
Hi Stanley
The latest updates to Freematics One 4 can not compile. Errror shows mssing datalogger.h.
Posted: Tue Jul 25, 2017 10:09 pm
Which sketch?
Posted: Wed Jul 26, 2017 2:54 am
by Polkpolk
Posted: Wed Aug 09, 2017 12:38 am
by stevel95
Using Arduino 1.8.2 IDE, Aug 7 download of source from github, compiling firmware_v4/datalogger for a FreematicsONE device.
My compile error is "datalogger.h:10: error: 'SDLib' is not a namespace-name". I assume no additional libs need to be included and that all are in the header files? Thanks in advance for the help.
