Hi
I'm interested in developing android application that would connect with the dongle via the bluetooth. Is there any documentation&resources about commands and how to do it with the Freematics adapter ?
Regards
Android bluetooth connection with OBD-II Adapter
jkozlowski
Re: Android bluetooth connection with OBD-II Adapter
Hi, did someone already found a solution to this question?
The freematics vehicle data logger is a programmable device. So you can make your own command-set and simply let it stream out data like reference datalogger sketch does.
Is there anywhere an example with the implemenation how to receive the command-set on the other side? (Android device). How can I broadcast a message from the freematics vehicle data logger over BLE and receive it on an android device?
regards
regards
We don't provide android code. You can use serial terminal app to receive text sent from the device.
