Problem OBD UART adapter
Venturi
Contact:
Post by Venturi »
I try to make a dashboard for my french rally car in KWP2000 5 bauds but my UART adapter V1.2 doesn't work.
I try with the new library OBD.h and OBD.cpp but nothing.
I try on another car, nothing. I try with the sample program "LED RPM", nothing.
Can I send you my code to have another look ?
Before, in your codes you write #include <OBD.h> but when I write this I have an error message so I write #include "OBD.h" and the compilation is good !
Is it normal ?
Thanks for your help.
Best regards.
Venturi
Contact:
Re: Problem OBD UART adapter
Post by Venturi »
Since thé last post, my program work perfectly, but none on my car with KWP 2000 low protocol.
It work only once and after the UART block. I must reload another program to unlock it.
I use OBD.h and .cpp December version. Before and after my program doesn't work.
Can you help me ?
I just committed a fix for current issue. Please update your OBD library with the latest revision in github and give another try.
