Page 2 of 2
Re: Kit #3:Blank, white display after uploading Megalogger
Posted: Thu Mar 19, 2015 9:48 pm
by JulianS
Here are some pictures of the arduino with the display:
- 2015-03-19 11.24.35_.jpg (11.31 KiB) Viewed 16332 times
- 2015-03-19 11.23.58_.jpg (8.15 KiB) Viewed 16332 times
Posted: Sun May 10, 2015 5:57 pm
Are you sure the sketch is successfully compiled and uploaded to the board. I also noticed the screen shield is not fully inserted.
Posted: Sat Oct 03, 2015 3:09 am
by johnward
Hi there,
i had the same problem ( lol .. no, plugged in all the way)
I was using the old 12c / serial board and had to uncomment LCD driver to ->> LCD_ILI9325D lcd; /* 2.8" ILI9325 based TFT LCD */
then it worked. I also found that the GPS didnt work. I had the 5 HZ version so i had to change teh baud rate to 38400 for the GPS.
Now i have working LCD and Working GPS
Now, i just need to figure out why the SD card doesnt work
Posted: Wed Oct 07, 2015 5:31 pm
What you've got is 3.2" LCD instead of 2.8". It seems you did that wrong in config.h.
