Only Board version OBD adapter
penjoseph
Post by penjoseph »
Is there an option to buy the UART OBD adapter board with dupont 2mm pins - without the case & OBD connector ? I would like to mount Arduino & the OBD adapter on a single board.
Re: Only Board version OBD adapter
The connector must be attached. You can add a comment when placing an order for no case and cable.
penjoseph
Post by penjoseph »
One of the main reasons why I asked for the board only version was to provide a switched +12v connection to the OBD adapter.
In my car (2010 Hyundai Accent - CRDi diesel) the female OBD connector
pin16 remains always ON irrespective of the position of the ignition key.
Guess I will buy the case version itself & use a male-female OBD extender cable to tap the OBD power connection (pin16) & connect it to the +12v to the accessory (car stereo) power.
penjoseph
Post by penjoseph »
I have placed the order for UART OBD adapter through paypal. Order ID: 879
Kindly provide 5v output & XH-2.5 4x1 connector for the adapter. There is no option to confirm it post payment.
Thank you for your order. I saw you have chosen XH-2.5 Connector (4-Pin x 1) in your order.
