Code Clearing Issue
Re: Code Clearing Issue
Please download the latest GUI software package and perform a firmware upgrade for the emulator.
mrobd2dude
Post by mrobd2dude »
stanley wrote:Please download the latest GUI software package and perform a firmware upgrade for the emulator.
Hi, yes I already did that if you read my message. I have the latest GUI and the latest firmware loaded. Still 6 codes that do not show up anywhere and a freeze frame. Any other info I could provide to help you out?
rwhite7851
Post by rwhite7851 »
I downloaded and installed firmware update 0820.
This did not fix the problem that users are reporting: "MIL is ON 6 codes"
Also, I can only see 1 DTC at a time - only the last one is reported even with 2 others set from the GUI.
What OBD-II hardware/software are you using with the emulator?
mrobd2dude
stanley wrote:What OBD-II hardware/software are you using with the emulator?
At least I'm not the only one with this issue... I'm pretty sure its nothing to do with my OBD2 reader hardware or software.
I tried it with 2 different types... the typical cheapo ELM327 ebay bluetooth reader using Torque and also with the OBDLink-SX Scantool from Scantool.net (http://www.scantool.net/obdlink-sx.html)
Here are some screenshots using the OBDLink-SX with two different softwares - OBDWiz and EasyOBD.
As you can see, both show the same Freeze Frame, MIL on and the same unknown 6 mystery codes.
Image Image Image
Image Image Image
mrobd2dude
Soo is there any possible answer or fix for my issues above ^^
