Problems with reading with Arduino OBD-II Logger Kit #3
Mcsquizzy
Re: Problems with reading with Arduino OBD-II Logger Kit #3
Post by Mcsquizzy »
Gabla, I changed the
#define OBD_PROTOCOL 0
to
#define OBD_PROTOCOL PROTO_KWP2000_FAST
When I tried to build the megalogger.ino file (version megalogger-src-20140612) within CodeBlocks, I received this error:
megalogger.ino||In member function 'void COBDLogger::setup()':|
megalogger.ino|94|error: 'PROTO_KWP2000_FAST' was not declared in this scope|
||=== Build failed: 1 error(s), 76 warning(s) (0 minute(s), 6 second(s)) ===|
Then, I tried the newest megalogger.ino project folder (version megalogger-src-20140907) but recieved even more errors, without modifying any of the code:
megalogger.ino|97|error: 'PROTO_AUTO' was not declared in this scope|
megalogger.ino||In member function 'void COBDLogger::loop()':|
megalogger.ino|149|error: 'getVoltage' was not declared in this scope|
||=== Build failed: 2 error(s), 78 warning(s) (0 minute(s), 9 second(s)) ===|
Any ideas?
Your OBD library might not be up-to-date.
Mcsquizzy
Post by Mcsquizzy »
I downloaded the .zip file containing all files and libraries (http://sourceforge.net/projects/obdcon/files/logger/)
I downloaded version megalogger-src-20140907.zip and opened the CodeBlocks project file.
The older version (megalogger-src-20140612.zip) seemed to compile fine, but it's just the new one... Maybe there are other library files which are interfering with the CodeBlocks project?
Gobla
Post by Gobla »
Most definitely your OBD library that is not up to date.
PROTO_KWP2000_FAST is defined in OBD.h.
You could try to update the following folder: "CodeBlocksDir\arduino\libraries\OBD" with the files from your download in "libraries/OBD".
You could also update the other libraries as well.
