ELM327 Connecting to Emulator
cptreese
Post by cptreese »
I just got my emulator in, super excited, I was hoping to connect this emulator to an ELM327 but it can't find the protocol. Any tips on how to get this working?
fruitoperation
Re: ELM327 Connecting to Emulator
Post by fruitoperation »
Ensure the emulator is set to simulate a car's OBD-II protocol properly. Most emulators allow you to select a specific protocol, such as ISO 9141-2, CAN, KWP2000, or others. Make sure the emulator is set to a protocol supported by the ELM327 device.
bev10
Post by bev10 »
To connect an ELM327 device to an emulator, ensure that the emulator supports OBD-II protocols. xfinity customer support billing Use compatible software (like Torque or Car Scanner) on your PC or mobile device, and connect via Bluetooth or USB. Follow setup instructions for proper communication.
alk
Post by alk »
Hello there, wanted to know if got any results trying to connect elm327 to emulator. I have tried several lectors for CAN traffic but emulator only seems to be sending CAN messages with all 0 data, even after modifying values using Freematics GUI or raw AT commands.
cptreese
Post by cptreese »
Yeah There is some sort strange traffic when the protocol is set to CAN500Kbps/11bit
Here is a video of it happening
https://share.vidyard.com/watch/JYpWcSvSoyLTLquLTm844J?
Anyone that can explain that traffic, I would appreciate it
cptreese
Post by cptreese »
Also I managed to hook it up to an ELM327 I highly recommend using Veepeak
https://www.amazon.com/gp/product/B073X ... UTF8&psc=1
Works pretty well and I've been able to learn a ton about how an ELM327 does it's thing. Use a pigtail OBD2 connector one side ELM327 other side your sniffer
