Freematics ONE+ Traccar Edition
trackernsw
Post by trackernsw »
The tracker's aren't working. Is the devices faulty I don't understand.
After receiving the trackers, it was put on two devices. They are connecting to the traccar server.
The tracker were sending data to the server however not every trip. Around 30%-50% of the daily trips it was sending data.
And this week the trackers are still online, like the tracker is still sending data every 10 minutes as if the vehicle is stationary
Logs from the traccar server; (as the time is in UTC, from the following logs, the vehicle was on 5:20 left the premises 5:21)
2022-02-14 12:19:03  INFO: Started Server@70f4f89e{STARTING}[10.0.7,sto=0] @26472ms
2022-02-14 12:19:04  INFO: Health check enabled with period 480000
2022-02-14 12:33:28  INFO: [a361e80f: freematics < 49.195.1.188] HEX: 45353931474147342345563d372c54533d3830383939333037392c49443d45353931474147342c5353493d2d37332c56494e3d4a544650543232503530303030313239322c2a3542
2022-02-14 12:33:28  INFO: [a361e80f: freematics > 49.195.1.188] HEX: 312345563d372c52583d312c54533d3830383939333037392a3943
2022-02-14 12:48:53  INFO: [a361e80f: freematics < 49.181.171.116] HEX: 45353931474147342345563d372c54533d3830393931373632362c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3534
2022-02-14 12:48:53  INFO: [a361e80f: freematics > 49.181.171.116] HEX: 312345563d372c52583d312c54533d3830393931373632362a3937
2022-02-14 12:55:36  INFO: [cbfca16f] connected
2022-02-14 12:55:36  INFO: [cbfca16f: osmand < 127.0.0.1] HEX: 504f5354202f20485454502f312e310d0a4163636570743a202a2f2a0d0a557365722d4167656e743a204d6f7a696c6c612f352e3020284c696e75783b20553b20416e64726f696420342e342e323b20656e2d55533b20484d204e4f5445203157204275696c642>
2022-02-14 12:55:36  INFO: [cbfca16f: osmand > 127.0.0.1] HEX: 485454502f312e31203430302042616420526571756573740d0a636f6e74656e742d6c656e6774683a20300d0a0d0a
2022-02-14 12:56:06  INFO: [cbfca16f] disconnected
2022-02-14 13:04:26  INFO: [a361e80f: freematics < 49.179.31.228] HEX: 45353931474147342345563d372c54533d3831303834353133362c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3438
2022-02-14 13:04:26  INFO: [a361e80f: freematics > 49.179.31.228] HEX: 312345563d372c52583d312c54533d3831303834353133362a3842
2022-02-14 13:19:50  INFO: [a361e80f: freematics < 49.186.52.120] HEX: 45353931474147342345563d372c54533d3831313737343631302c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3437
2022-02-14 13:19:50  INFO: [a361e80f: freematics > 49.186.52.120] HEX: 312345563d372c52583d312c54533d3831313737343631302a3841
2022-02-14 13:35:14  INFO: [a361e80f: freematics < 49.195.57.1] HEX: 45353931474147342345563d372c54533d3831323639383534312c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3530
2022-02-14 13:35:14  INFO: [a361e80f: freematics > 49.195.57.1] HEX: 312345563d372c52583d312c54533d3831323639383534312a3933
2022-02-14 13:50:38  INFO: [a361e80f: freematics < 49.181.173.100] HEX: 45353931474147342345563d372c54533d3831333632323937382c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3532
2022-02-14 13:50:38  INFO: [a361e80f: freematics > 49.181.173.100] HEX: 312345563d372c52583d312c54533d3831333632323937382a3935
2022-02-14 14:06:03  INFO: [a361e80f: freematics < 49.186.59.40] HEX: 45353931474147342345563d372c54533d3831343534373239392c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3535
2022-02-14 14:06:03  INFO: [a361e80f: freematics > 49.186.59.40] HEX: 312345563d372c52583d312c54533d3831343534373239392a3938
2022-02-14 14:21:27  INFO: [a361e80f: freematics < 49.195.62.243] HEX: 45353931474147342345563d372c54533d3831353437313634362c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3445
2022-02-14 14:21:27  INFO: [a361e80f: freematics > 49.195.62.243] HEX: 312345563d372c52583d312c54533d3831353437313634362a3931
2022-02-14 14:36:51  INFO: [a361e80f: freematics < 49.195.31.94] HEX: 45353931474147342345563d372c54533d3831363339363038342c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3531
2022-02-14 14:36:51  INFO: [a361e80f: freematics > 49.195.31.94] HEX: 312345563d372c52583d312c54533d3831363339363038342a3934
2022-02-14 14:52:16  INFO: [a361e80f: freematics < 49.179.9.168] HEX: 45353931474147342345563d372c54533d3831373332303338312c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3435
2022-02-14 14:52:16  INFO: [a361e80f: freematics > 49.179.9.168] HEX: 312345563d372c52583d312c54533d3831373332303338312a3838
2022-02-14 15:07:40  INFO: [a361e80f: freematics < 49.186.67.86] HEX: 45353931474147342345563d372c54533d3831383234343339332c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3445
2022-02-14 15:07:40  INFO: [a361e80f: freematics > 49.186.67.86] HEX: 312345563d372c52583d312c54533d3831383234343339332a3931
2022-02-14 15:23:04  INFO: [a361e80f: freematics < 49.179.13.93] HEX: 45353931474147342345563d372c54533d3831393136383639382c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3543
2022-02-14 15:23:04  INFO: [a361e80f: freematics > 49.179.13.93] HEX: 312345563d372c52583d312c54533d3831393136383639382a3946
2022-02-14 15:38:28  INFO: [a361e80f: freematics < 49.181.200.40] HEX: 45353931474147342345563d372c54533d3832303039323739332c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3443
2022-02-14 15:38:28  INFO: [a361e80f: freematics > 49.181.200.40] HEX: 312345563d372c52583d312c54533d3832303039323739332a3846
2022-02-14 15:53:52  INFO: [a361e80f: freematics < 49.179.32.192] HEX: 45353931474147342345563d372c54533d3832313031363731342c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3432
2022-02-14 15:53:52  INFO: [a361e80f: freematics > 49.179.32.192] HEX: 312345563d372c52583d312c54533d3832313031363731342a3835
2022-02-14 16:09:16  INFO: [a361e80f: freematics < 49.181.200.223] HEX: 45353931474147342345563d372c54533d3832313934313036382c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3442
2022-02-14 16:09:16  INFO: [a361e80f: freematics > 49.181.200.223] HEX: 312345563d372c52583d312c54533d3832313934313036382a3845
2022-02-14 16:24:40  INFO: [a361e80f: freematics < 49.179.36.54] HEX: 45353931474147342345563d372c54533d3832323836353132382c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3445
2022-02-14 16:24:40  INFO: [a361e80f: freematics > 49.179.36.54] HEX: 312345563d372c52583d312c54533d3832323836353132382a3931
2022-02-14 16:40:05  INFO: [a361e80f: freematics < 49.181.201.156] HEX: 45353931474147342345563d372c54533d3832333738393435342c49443d45353931474147342c5353493d2d37312c56494e3d4a544650543232503530303030313239322c2a3536
2022-02-14 16:40:05  INFO: [a361e80f: freematics > 49.181.201.156] HEX: 312345563d372c52583d312c54533d3832333738393435342a3939
2022-02-14 16:55:29  INFO: [a361e80f: freematics < 49.186.83.255] HEX: 45353931474147342345563d372c54533d3832343731333635392c49443d45353931474147342c5353493d2d37332c56494e3d4a544650543232503530303030313239322c2a3533
2022-02-14 16:55:29  INFO: [a361e80f: freematics > 49.186.83.255] HEX: 312345563d372c52583d312c54533d3832343731333635392a3934
2022-02-14 17:10:53  INFO: [a361e80f: freematics < 49.195.81.73] HEX: 45353931474147342345563d372c54533d3832353633373830322c49443d45353931474147342c5353493d2d38352c56494e3d4a544650543232503530303030313239322c2a3532
2022-02-14 17:10:53  INFO: [a361e80f: freematics > 49.195.81.73] HEX: 312345563d372c52583d312c54533d3832353633373830322a3930
2022-02-14 17:26:17  INFO: [a361e80f: freematics < 49.195.81.195] HEX: 45353931474147342345563d372c54533d3832363536323138312c49443d45353931474147342c5353493d2d39332c56494e3d4a544650543232503530303030313239322c2a3446
2022-02-14 17:26:17  INFO: [a361e80f: freematics > 49.195.81.195] HEX: 312345563d372c52583d312c54533d3832363536323138312a3845
2022-02-14 17:41:42  INFO: [a361e80f: freematics < 49.181.203.25] HEX: 45353931474147342345563d372c54533d3832373438363536382c49443d45353931474147342c5353493d2d38312c56494e3d4a544650543232503530303030313239322c2a3542
2022-02-14 17:41:42  INFO: [a361e80f: freematics > 49.181.203.25] HEX: 312345563d372c52583d312c54533d3832373438363536382a3944
2022-02-14 17:57:06  INFO: [a361e80f: freematics < 49.186.94.133] HEX: 45353931474147342345563d372c54533d3832383431303638362c49443d45353931474147342c5353493d2d39352c56494e3d4a544650543232503530303030313239322c2a3535
2022-02-14 17:57:06  INFO: [a361e80f: freematics > 49.186.94.133] HEX: 312345563d372c52583d312c54533d3832383431303638362a3932
2022-02-14 18:12:30  INFO: [a361e80f: freematics < 49.186.97.25] HEX: 45353931474147342345563d372c54533d3832393333353033352c49443d45353931474147342c5353493d2d39312c56494e3d4a544650543232503530303030313239322c2a3443
2022-02-14 18:12:30  INFO: [a361e80f: freematics > 49.186.97.25] HEX: 312345563d372c52583d312c54533d3832393333353033352a3844
2022-02-14 18:27:55  INFO: [a361e80f: freematics < 49.181.204.82] HEX: 45353931474147342345563d372c54533d3833303235393437372c49443d45353931474147342c5353493d2d3130372c56494e3d4a544650543232503530303030313239322c2a3831
2022-02-14 18:27:55  INFO: [a361e80f: freematics > 49.181.204.82] HEX: 312345563d372c52583d312c54533d3833303235393437372a3934
2022-02-14 18:43:20  INFO: [a361e80f: freematics < 49.179.64.13] HEX: 45353931474147342345563d372c54533d3833313138343438392c49443d45353931474147342c5353493d2d3130332c56494e3d4a544650543232503530303030313239322c2a3745
2022-02-14 18:43:20  INFO: [a361e80f: freematics > 49.179.64.13] HEX: 312345563d372c52583d312c54533d3833313138343438392a3935
2022-02-14 18:58:44  INFO: [a361e80f: freematics < 49.195.85.24] HEX: 45353931474147342345563d372c54533d3833323130383738352c49443d45353931474147342c5353493d2d37332c56494e3d4a544650543232503530303030313239322c2a3530
2022-02-14 18:58:44  INFO: [a361e80f: freematics > 49.195.85.24] HEX: 312345563d372c52583d312c54533d3833323130383738352a3931
trackernsw
Re: Freematics ONE+ Traccar Edition
Nothing was configured on tracker's, there were plugged straight into the port from the package.
I think this is the same issue I have
https://freematics.com/forum/viewtopic.php?p=48483
https://www.traccar.org/forums/topic/fr ... urs-or-so/
trackernsw
UPDATE:
The tracker is working if the device is unplugged & replugged when the vehicle is on after the vehicle was off. So the problem is the wake up after standby
trackernsw
Stanley,
Could we get the code updated so I don't need to manually unplug the tracker re-plug it (which is annoying)?
Happy to sponsor.
