Support For multiline responses
Bruce
Post by Bruce »
I created an Android app that interfaces with a Bluetooth OBDII adapter. I've been successfully using the emulator for about a week now but ran into an issue where if you send multiple PIDs it only returns the first in the list. I've tried using my app with a few different OBDII adapters on my car and actually get the expected multi-line response.
For example I send:
(rpm, speed, intake air temp, throttle pos)
01 0C 0D 0F 11
response:
41 0C 0F A0  << values returned only for 0C (rpm)
Configuration:
atdp returns ISO 15765-4 (CAN 11/500)
The software is set to CAN 500Kbps/11bit
Please let me know if I'm missing something or if this is not supported.
- thanks
justynjj
Re: Support For multiline responses
Post by justynjj »
I know this post was a while ago, but I am experiencing a similar issue. I am issuing a batch request as Bruce was but am not seeing a multiline response from the emulator as would be expected.
Would I be correct to assume that this is something that isn't currently supported?
Thanks,
Justyn
Multiple PID request should be like this:
01 0C\r
01 0D\r
01 0F\r
01 11\r
