Running on trucks (24v)
Can run the OBDII adapter on trucks? at 24V
Re: Running on trucks (24v)
24V voltage should be no problem. You also need to check the protocol. Some trucks use J1939 which our OBD-II adapter does not support.
stanley wrote:24V voltage should be no problem. You also need to check the protocol. Some trucks use J1939 which our OBD-II adapter does not support.
A lot of thanks stanley, we are trying to read in a MAN TGX vehicle, it seems use J1939 protocol, how can I read it?
Best regards
Sorry J1939 is not supported though 24v voltage has no problem.
stanley wrote:Sorry J1939 is not supported though 24v voltage has no problem.
A lot of thanks stanley.
Dear Support ,
It Will Work with OBDII HINO 300 Series Truck ? how i can confirm its J1939 OR another Protocol Supported ?
Trucks with 24V system is not supported at the moment.
Hello, Stanley!
Please write me an email or private message. I want to contact with you regarding possibility of 24V truck support from your side.
