I have got couple of the OBD-II adapters for Arduino, but I can not seem to use them with my own code.
What is the supported command set?
I try for example to use the ATMA command to monitor all traffic and extract, but the only response I am getting from the  adapter is "OK". I have set all the other parameters and the sequence of commands used to initialize protocols, etc, is working fine on a generic bluetooth OBD adapter.
						ELM command set
Re: ELM command set
So other commands work well?
						Re: ELM command set
ATMA may not necessarily be supported with your car (or elm327) it doesnt work for me with them.
