Problem when setting more than one DTC code
Alex4WAG
Post by Alex4WAG »
I received your OBD-Emulator MK2 this week. This is a very nice tool :P
Unfortunately I experienced a problem when setting more than one DTC-code.
Although the GUI confirms that more than one code is set simultanously, I do only get one DTC-code when checking with an OBD-tool.
This is a function that I urgently need for my development work.
Can you help?
Regards,
Alex.
Re: Problem when setting more than one DTC code
Just set one more time to add a DTC code. Up to 6 DTC codes can be set.
Alex4WAG
Post by Alex4WAG »
that is exactly what I am doing.
For example after setting 3 different DTCs the GUI confirms with "Totally 3 DTCs has been set".
But when checking with a fault code reader only the last DTC ist set.
When checking with a CAN-tool my request is: ($7df) $01 $03
The reply then is: ($7e8) $04 $43 $01 $03 $00
Fault codes 0100, 0200 and 0300 should be set.
Can you help?
Can you try upgrading with latest firmware which has just been released?
Alex4WAG
Post by Alex4WAG »
Yes, I did but the problem persists with the firmware dated Dec. 9th.
cavalier
Post by cavalier »
I am facing with this problem too. I have updated firmware but the problem isn't fixed yet.
chad.schnitz
Post by chad.schnitz »
I am having the same issue <p>
Only the last code shows
4 DTCs entered
4 DTCs entered
bernardofca
Post by bernardofca »
Same problem here.
At least please acknowledge the problem and suggest a target resolution date.
