OBD-II Adapter (UART) doesn't work on ISO9141-2
giulio
Post by giulio »
I tried to make the adapter working on my motorcycle (protocol ISO9141-2) by running the simple RPM program provided as example but it doesn't work. I double checked all the wiring and all is perfect. No reading from the ECU, with motor on, off, at high rpm, at low rpm... nothing.
I made another attempt: I've inverted the logic of the program to turn on the led 13 when RPM are lower than 3000 and turn it off at higher values. Again no results, the led stays off :cry:
I thought that maybe the problem is located in the initialization phase, so I modified the program to turn on the led during the init (the setup function) and turn it off at the end (see code below).
After uploading the program, I can see clearly the led turning on and off but after... nothing happens.
As further step I have inserted also other debug "flashing led code" inside the IF statement but no results, as I understand the instruction obd.read(PID_RPM, value) always returns the false value.
Please note that I can read OBD2 codes on my motorcycle by using my notebook and a simple (freeware) program. Maybe the adapter does not work on protocol ISO9141-2???
Any clue?
* Distributed under GPL v2.0
#include <Arduino.h>
#include <Wire.h>
#include <OBD.h>
COBD obd;
void setup()
  pinMode(13, OUTPUT);
  digitalWrite(13,HIGH); // debug: turn the led ON when init starts
  obd.begin();
  while (!obd.init());
  digitalWrite(13,LOW);  // debug: turn the led OFF when init ends
void loop()
  int value;
    digitalWrite(13, value < 1800 ? HIGH : LOW);
dcolemans
Re: OBD-II Adapter (UART) doesn't work on ISO9141-2
Post by dcolemans »
I don't see any reply to your question/problem. I just got my OBD-II I2C Adapter and am relying on on ISO9141 protocol (2004 Prosche Boxster S 986), and trying the test RPM program also. My symptom is that when first plugged in the adapter does its blue flashing for a few seconds and then quits. I tried it several times and on occasion, if I rev the engine to 3000 before the blue flashing quits, the pin 13 LED does light up. I got this to work a couple of times, but not reliably. The problem could be related to yours.
So it sort of works. Anyone with any ideas here? Stanley?
kyr
Post by kyr »
I am afraid I have a similar problem with ISO9141-2. I have the V2 with the embedded GPS. It works ok when I plug it in, but sometimes it simply stops logging, due to the init() function. In any case, when I switch the engine off and then ON, it never initiates again. I am afraid it has to do with the ISO9141-2 protocol.
I will test in another car, to see if this happens as well.
BR
You mean it works for a very short time after plugged in?
dcolemans
Post by dcolemans »
My adapter works for a short time (a few seconds) and than stops working. Sometimes it works long enough for me to see that the LED sketch does light the LED at 3000 RPM. So it does have communication and does get the RPM data for a short time. Any ideas why it would stop after a few seconds?
